Re: Switching from '96 75hp Force to '86 150hp Johnson
OMC used to use completely different cable ends than Merc or Force. I'm not too sure about the newer Force engines so you will need to check the ends inside the engine hood. If they look different, you will have no choice but to use the OMC control box and cables. I am also reasonably certain that the ignition switch is different also so it is probably a given that you will also need to swap out the wiring harness.
75 to 150, huh? You will definitely notice the performance difference but don't expect twice the speed. Because horsepower need usually increases by the square while speed increases linearly, generally speaking it takes 4 times the horsepower to double the speed. This is, of course, not a hard and fast rule though.
