Switching depth finders
kevtherev
I am removing a Pinpoint 7520 depth finder and replacing it with a Lowrance HDS-5x. Is there an adapter to connect my existing wiring to the new unit? Should I start over with all new wiring? This is on a Bass Cat bass boat so access is pretty limited. I am proficient at wiring and soldering etc. so give me the straight scoop! Thanks for the help.
kevtherev
dingbat
Re: Switching depth finders
New transducer, new power cables. Tear it all out and start over
marcortez
The only thing you can keep is the power supply.
12V supply is 12V supply, no matter the machine.
Meaning the wiring from the battery to a bus, to the finder.
