Switch to jet unit
boatyardbilly
Is it possible to switch from a prop to a jet unit on a 1968 20 hp Johnson? Anybody know that one?<br />Thanks in advance!!!!!!<br /><br />Boatyardbilly
Walter
Re: Switch to jet unit
A 20 hp outboard driving a jet pump is about the equivalant of a 10 hp with a prop...depending on the boat it may be more like a 5 hp. IF your boat will even plane with a 20 hp pump...it will require a whole lot of distance at WOT to get it there. Be prepared to rebuild that motor in a very short time as well, for the pump will cause it to red line most of the time. I'm not against jet pumps...they're great when matched with an appropriate power unit. I just don't think a '68 20 hp Johnson is it.
