Switch panels
Fury2
Does anyone know if you can use the seasense 6 gang switch panel horizontally? It is shown vertical. I assume you can just switch the labels around. I have such little room on the dash. That panel seems like a good one. I have a small council on a 16 ft Lund Fury. Any other suggestions on switch panels is great.
Silvertip
Honorary Supreme Mariner
Re: Switch panels
Switches don't care which way they are oriented.
gm280
Re: Switch panels
As long as they are pretty much water proof or water resistant type marine switches I see no problem. Just mount any type switch or electronic components (lights, fuse holders, gauges etc.) where there is little chance of water pooling around them and keep water from seeping by the switch openings and getting behind them to the actual terminals to keep corrosion at bay.
