CeeJ1791
Thread starter- Joined
- Aug 16, 2017
- 44
I'm looking to completely rewire my boat to include a circuit breaker. I have a Blue Sea 5025 Fuse Block with attached Neg Bus Bar and a Blue Sea WeatherDeck Swich only panel. Both have contradictory wiring diagrams. The switch is pre-wired with a single red wire, that the wiring diagram states should be connected to the supply wire. From there, positive leads run from the switch to the breaker and then to the load. The Fuse Block diagram, however has the positive and negative supply going to the breaker and the red lead wire from the switch to one of the breakers on the Fuse Block. What is the correct wiring for this setup?
