Thank for the reply. The original lower unit was damaged . I am currently disassembling it for repair. A new experience. I may try aswap of the housings.The 77 engine uses a different shifting mechanism under the bottom carb. That belcrank system on the 77 means that the lower unit shifts backwards from the 78 and later models. You may be able to swap the 79 intake manifold so that you can use the 79 shifting mechanism instead. One of the experts on the board will chime in with the correct information.
