Frank Acampora
Thread starter- Joined
- Jan 19, 2007
- 12,004
This question frequently comes up so here is the answer: You can swap ANY lower unit from any 3 or 4 cylinder Chrysler or Force between 1979 and early 19900s --When mercury changed to a Mercury lower unit. The exception is the Force 70 and 75.
However, if you want to swap a later unit with a Mercury water pump onto an earlier midleg--like I show here-- You must do some minor modifications.
In order to clear the rear bolt and boss on the Mercury water pump, you must remove some metal from the web. In order to clear the front two gearcase cover bolts, you must also sometimes remove a little metal from the front two lower unit bolt bosses.
The mounting bolt pattern is all the same. With earlier lower units with a one piece drive shaft, you need to be certain that the drive shaft is the correct length for your particular engine--long shaft or extra-long shaft. With two piece drive shaft lower units, It doesn't matter--all the lower units are the same and you merely need to get the correct upper drive shaft to fit your engine. Unfortunately, the first two photos show that I lost the gears in my older lower unit and needed to replace it with a later model Force lower.
