Re: swamped motor
If you did not completely sink the motor, like "glug, glug, glug" to the bottom of the lake,then water probably didn't get inside to the crank and piston bearings. Just remove the lower unit to make sure it isn't the thing that is locked up, set the motor spark plug hole up, spray inside the spark plug holes with a lot of penetrant, and let it soak. The key thing is not to try to force the rings to break loose, because they are brittle and will crack and break. Just a slight wiggle back and forth a few times, then respray and wait to soak in again. I have a 3 hp that took a week to break loose, and I had the whole head soaking in a bucket of penetrant.
