Suzuki trim cylinder leak
eaglejax
Question for the maritime gurus. On a 99 suzuki dt150, are the trim piston caps standard or reverse thread. Have a leaking seal and can't break the cap loose to change. Manual only describes tilt cylinder but doesn't have the info. for changing seals on the trim pistons
eaglejax
Problem solved. Standard thread. Broke a few pins on wrench and had to machine a few more. Still had to use a punch to break it loose.
