Charles Cote
Thread starter- Joined
- Mar 30, 2010
- 3
I have a 1999 Suzuki 4 stroke DF 60 T. I am trying to make it work (it currently doesn't, imagine that ).
If you look at the engine from the front with the cowling off, located just about mid height and to the right side a bit is a large brass colored port, as in for a vacuum tube. It faces the center of front face of the engine.
It appears that a tube should be on it (but there is not one). If you occlude the aperture with your finger while it is running, it adversely affects the engine.
Does anyone know if there SHOULD be some sort of hose or tube attached to this one ? and if so. . where should the other end go ?
Thanks
Chuck
Thanks
Chuck
