suzuki prop vs turning point 4 blade prop; looking for advise
chrisgt
I am trying to setup the correct prop on my home build aluminum boat, since this is the first one of this design to be constructed, I started with a guess at a 15 pitch from suzuki. Now that I'm through enough break to throttle up, in I'm hitting redline and don't have quite grip on the water I'm looking for, nor does it have very good reverse thrust. I don't really need more speed, I still like the 15p for when I load the boat down with passengers and gear, holeshot for skiing, etc.
In the past I've been very impressed with turning point's 3-blades so I checked for this engine, they only offer the 4-blade (not the one with two different blades) and they claim you don't lose top end with it.
Does anyone have direct experience with their claims? I'm thinking about going with a 15p 4-blade, if their claims are true, i should get the same top end, same economy, better holeshot and more reverse torque. Seems like it shouldn't be possible, but maybe it is too good to be true?
Otherwise I'm open to recommendations. I want to stay with aluminum so I don't wipe out my LU if I hit a rock, and I have never had great performance from the cheap Michigan wheel or Solas props; every time i swap one of those for a turning point it's a whole new boat.
My boat:
Texasmark
My boat:
I have been a Turning Point Hustler prop owner for decades. I like all the things they do to an aluminum prop......however having bought a couple of the dual type 4 blade props, I'm not sure I realized what the designers had in mind.....I would think that having 2 different functioning type blades on a 4 blade props would give you the best of both worlds...surely the designers did their homework on that. I have 2 of those "sitting on the shelf".
On the regular 4 blade design, "I'm guessing" that they are basing their (no speed loss) on the fact that they cup most all their props and most alum. mfgrs. of which I am aware, don't.
chrisgt
Makes sense, the suzuki prop has no cup and no rake; it's pretty basic. When I changed from such a prop to the same pitch hustler on a different boat I gained a few kts, improved fuel economy, improved hole shot, and gives significantly better grip in the water. I couldn't believe what a difference it made.
I'm hoping that since a 3 blade 15p prop can now easily hit redline, the 4 blade hustler will drop me into a better RPM range and may not even lose speed just because it's more efficient. Not looking for a speed demon, cruising at 20kts makes me perfectly happy.
Texasmark
Sounds like you are on the right track having mentioned your speed preference.
Stinnett21
Seeking clarification, when you say "On the regular 4 blade design" are you referencing to something other than the "dual geometry" 2 different blades 4 blade aluminum? Reason for asking is that when I look at their website the only aluminum offered in 4 blades (other than the cleaver) is the dual geometry design. Maybe I'm mis-reading you. And when you say "I have been a Turning Point Hustler prop owner for. decades. I like all the things they do to an aluminum prop.", you're referencing the 3 blade?
Texasmark
No sir you are spot on. Apparently they felt that the dual design was a winner based on further in-house testing, or customer feedback. So they discontinued the old design (opinion).
chrisgt
Maybe I'm misreading their website, but I got the impression the 4-blade prop for a suzuki 90 was a standard 4-blad; in other words not the duel geometry style. I'll be pleasantly surprised if it is, but we'll see. It's on backorder which is probably good, gives me time to get some performance data and fuel economy numbers with the 3-blade suzuki prop.
I could have definitely put a 140 on this boat, i keep thinking about that haha. Not that I NEED the extra power, it'll do 30kts wide open and cruises in heavy chop really well at 20. but ... you know, i'm a guy, i always want more horsepower :) I tune every vehicle and 2 stroke outboard I own to within an inch of its life, I just can't help myself.
Stinnett21
I see the "dual geometry" and swept cleaver listed for Suzuki.
chrisgt
Yes, but it's only listed (as far as i can tell) for the df115A and up; for the larger size gear case. Maybe i'm missing something
Stinnett21
When I put a Suzuki 90 in their prop wizard it lists the Hustler 4 blade aluminum which I believe is the dual geometry.
chrisgt
it depends which one, according to their link here: https://turningpointpropellers.com/_CONTENT/hustler-aluminum-boat-propellers.php
This shows that it's dual geometry for the 4.75" gear case, and just the standard swept cleaver for the 4.25" gear case... even though they bear the same name! It's confusing. I also found out through more poking around you can actually get a 3 blade for the 4.25" gear case, they just don't list it in their prop wizard; turning point makes a great product, their customer support is great, but their website is terrible.
Chris1956
Honorary Supreme Mariner
I have found TP props are pretty good. Your rig looks pretty light, vs my fiberglass 21 footer. I had a 150HP Johnny and ran the 15"P TP 4 blade with the two different blades combo. I think it is an advantage, but minimal.
I think I would run a 3 blade prop with your boat. It should give better speed. TP is as good or maybe better than the OEM props and Mich Wheel.
chrisgt
The place I ordered from STILL HAS NOT shipped, so I've been rethinking. I can hit redline pretty easy and TP doesn't offer (really don't think) a 3-blade for this engine. Mercury black max makes a decent aluminum 3-blade that fits with the right hub kit, that may be better.
I may have to drop the engine a hole, I just really didn't feel like it. I have another boat with a 40hp where I raised the engine a hole and gained performance, but had horrible ventilation issues with (iirc) a michigan wheel; changing to the same pitch TP completely fixed the the ventilation, improved my holeshot, increased my top speed, and reduced my fuel consumption.
It didn't seem possible for a prop change to work all that magic, but it did. Pretty much sold me on TP props!
Texasmark
Look at the TP specs and compare to others......no comparison!!!!
Chris1956
I have run an alum TP Hustler on my speed boat with good results. This year I replaced it with a SS Michigan Apollo (cost 4-5 times as much), of the same pitch. The results are about the same. Not sure I made a wise investment for performance, however, a speedboat needs looks too and the Apollo provides that, especially when hanging on the lift.
chrisgt
Finally got the prop in, installed on the boat and .... NOPE!
Compared to the suzuki 15p prop, I lost 5kts, bang the rev limiter immediately at about 3/4 throttle, and went from ~6.7mpg to ~5mpg.
The boat rides much flatter in the water trimmed down, turns better, and since it has more grip it allows trimming the bow up farther.
Overall the prop works very well, it's just wildly under-propped.
It's weird to me how underpropped I am, the suzuki 15p made me think that maybe 17 would be more appropriate; but the general rule of thumb is that going 4 blade is like stepping up a pitch or two. In this case it went backwards. Oh well, I'm out camping all next week on an island, so I'll throw the suzuki prop back on the boat and do an exchange when I get back.
EXTREMELY torn if i should go 17p or step up to 19p at this point. It hit the limiter so easily that going to 17p will certainly be over 6k rpm, just how far is the mystery.
Texasmark
I agree on looks and later on in my boating years, I liked the shiny SS props on my black Mercuries. I guess seeing the shiny prop, in my mind, spelled "performance" whereas the OEM black aluminum just reflected "so-so" performance....so the TPs didn't last very long and wound up sitting on the shelf.
In retrospect, sitting here thinking about it, I used the TP $100 props as a yardstick in figuring what dimensions I wanted on a SS prop and it worked. Had I boated in rocky water, they would have stayed.
chrisgt
I finallyyyy got a 17p hustler 4 blade on there and.. I dunno. Up until about 22kts it gets the same, or maybe slightly lower fuel economy. I only took it out about 8 miles on a small local lake, so I'll have to go on a longer trip in the ocean to really determine that, but based on the fuel burn numbers on the SMG4 it's a tad bit worse.
The reverse grip is worse than the suzuki prop, I have to be a bit more aggressive in reverse, no big deal, but i wasn't expecting that.
The acceleration may be better, it's hard to tell, but it isn't night and day.
The grip on the water, though, THAT'S WHAT I NEEDED, it's the handling and grip that i really wanted.
Not sure the stern lift is appropriate for my boat, though, I have to trim up pretty far to get most efficient fuel burn and bring the spray back to the same place off the hull.
I have no idea why TP doesn't spec the 3 blade version for the suzuki, not sure if it would work or not. I honestly think it would be the better option for me or I may have to change brands.
