richardturner
Thread starter- Joined
- Aug 10, 2009
- 3
Can anyone help? I have a suzuki dt65 1993, which boggs down and cuts out when putting it in gear and putting the power on. It revs and idles fine. I have changed the plugs, throttle valve sensor and fuel pump, cleaned the carbs and fuel filter, also checked the oil flow sensor. I have also done a spark test and compression test and all is fine, and still have no luck.
