Suzuki DT60 starting
tomb23
Suzuki DT60, Starts well when you first hit the lake after a couple stop and go searching for the SPOT, it will not restart? I did however discover that if I use the power trim to raise the engine while I'm fishing then put about half way down (JUST IN THE WATER) then it will start almost every time ? Any thoughts would be great, Going to have to fix it (whatever it is) myself no oone around this area to help there at all.
gcboat
Re: Suzuki DT60 starting
Sounds like a fuel issue to me. You'd think by tilting it that the problem would be in the carbs. Try cleaning them out first. Then check for a possible leak in the primer bulb or the line itself. Maybe the carb assembly just needs to be re-torqued. Just throwing stuff at you.
tomb23
:) I discovered IT HAS A CHOKE works much better if ya use it Thanks to all
