suzuki dt30 wiring harness
gamekeepa
I have a 1986 suzuki d30.Is it possible to wire it up to a key ignition from a car or do you have to have the correct suzuki switch?The wire harness coming from the engine has 7 pins.Can i cut this off and just wire straight to an ignition?If so how do i do this?
Thanks
phwrd
Re: suzuki dt30 wiring harness
Welcome. . .
what type key switch do you have now ? Turn to start or push to choke & turn to start ?
Are the wires on your current swith attached to a harness, battery or wire nuts ?
Wouldn't use a car part ever on a boat...different type wire. Car parts don't weather well.
Hope that helps.
James R
The harness carries the main power + and -, the buzzer warning signal, the ingnition on/off and the choke. Every thing is possible but what a messy job. Automotive components are not suitable for marine applications.
I know the Suzuki replacement is not cheap but that is the only way to go.
predator165
hi i seen your post on wsf and thought to spent some time searching iboats , and here i see your listing also lololol
sorry to say that i havent been able to find anything sofar
ron ( irishron40 on wsf)
goodluck
Yepblaze
You would have to check the schematic diagram for your motor.
Some motors use power for the ignition and some ground a wire to kill the spark.
It's possible to do expensive damage if not dealt with correctly.
