75TowerOfPower
- Apr 17, 2009
- 331
I have recieved a 82 ish Suzuki DT 3.5 outboard. It is extremely clean like it looks like its a showroom engine from the inside. The outside obiviously sat out in the sun and faded the decals.
My problem right now is spark. I have never really had to tinker with a magneto and points (which I believe this has). I had looked through the flywheel and have seen the magneto and the points and the "pointer" doesn't move and sticks really bad. I can't seem to pull the flywheel with the stick the screwdriver on something solid and pop up the flywheel and turn and repeat. Well it hasn't bugded at all. Whould I find a steering wheel puller and use the 3 bolts on the flywheel for the manual rope.
The compression is very nice on this thing and the carb looks great. One thing i can't get to work fully is the fuel pump. I have apadted my cordless drill to turn the motor over instead of pulling all day long. I don't smell gas like I think I should but I need to get spark before the fuel.
Anyone with exprerience with these little guys? This will be my kicker on my 15'6" Tri Hull with a Merc. 155 Hp.
