Suzuki Dt150
birddog16
I have a 87 dt150 and would like to know how to disconnect the Oil Injection system.I just don't trust them...2nd I can't tell if the choke is working,It's slow on cold starts ..Thanks
99yam40
Re: Suzuki Dt150
Do a search on the web or the different forums for disconnecting oil injection to see what all you can find. the question is asked fairly often.
Most do not recommend it, just do the PPM on the system to keep it working properly.
birddog16
Re: Suzuki Dt150
Ok...Can I just unplug the oil level sensor and the oil flow sensor and mix my own gas??? As far as the choke....I can't tell if the electric choke is working,the motor is real slow to start on cold starts
Thanks
stylesabu
Master Chief Petty Officer
Re: Suzuki Dt150
there is a soliniod that activates choke plates, see if your getting power and ground. if not, will need wiring diagram. oil injection has a mechanical oil pump, its not recommended to stop putting oil in resiovour as motor can seize.check there are much more detailed post on oil injection system. I have a DT 75 suzuki
