Suzuki dt140 non oem efi pump
hopalong
Ok seems there are no threads on the forum regarding Suzuki efi low pressure electric pumps for DT115 or DT140 outboards except the oem ones. Has anyone used the after market USA hi performance pump model 15100-94900. Appears to be the same specs as the oem one. If so any problem with the pump. They have a 3 year warranty on them which makes it a good buy for replacement. Thanks
lakensea
What are you talking about? There's no such thing as an EFI low pressure electric pump for a DT115/140. 15100-94900 is the mechanical low pressure pump, readily available from Suzuki at a reasonable price.
hopalong
Look the dt140 2001 model as the 97-2000 model "have " an electric pump in addition to the mechanical pump! look it up at brownspoint.
Yes there is...look it up. Did you know the 97-2001 motors have an electric fuel pump as well as a mechanical one. That number is for the electric pump.
