suzuki dt 75 carbruator float angle
forsyth
hi i am looking for the carbruator float angle of my 1986 dt 75 suzuki outboard if you could give me info on that it would be great thanks:)
gsyfishy
Re: suzuki dt 75 carbruator float angle
The float should be even with the bottom of the carb when upside down. After cleaning install float pin and needle, then turn upsidedown and bend float arm untill its level with the bottom of the carb.
nbaker
The 1987 Dt75 model"VH" Suzuki manual calls for .39 to .47 (in). This measurement is made with the carb body inverted, using a caliper rule measure from were the main jet mounts into the center tower to lightly touch the float.
