Suzuki DF70 2004 wont tilt or turn over
nordicstallion
Hi kids.Went 7 miles out in heavy fog, engine ran great, as always.Fished awhile restarting engine to recover from drift, no problem. Started back in,started and ran fine,checked tilt position,a little high so tilted full down. Engine faultered and died. Woudnt turn over,and engine wont tilt. Power to everything ok. Started kicker ,elect start, no problem.With ignition turned on,all lights show with rev lim lite flickering rapidly. Turned to start, all lites out and high pitch squeel from tach. Any suggestions as to where to start looking appreciated. Vern
Rich Hargis
Re: Suzuki DF70 2004 wont tilt or turn over
Check the 30 amp fuse (in white holder) that is on the starboard side above the ECM cover.
lakensea
WRONG! Read his post - if the fuse is blown, there would be no power at all. He has a loose or corroded battery cable.
