Suzuki DF200 2004 WANT START IN NEUTRAL
cook 43
Need help I have a 2004 DF200hp. 4 stroke Suzuki outboard that want start in neutral. I can start in cold start by releasing the accelerator button and putting in forward or by putting it in reverse. When I bring it back to neutral the motor quits. I have checked the fuel line and water separator. Someone said it might be the jets are clogged in the carburetor. Trying to fix without going to a mechanic. ANY suggestions will be appreciated. thanks!
lakensea
Re: Suzuki DF200 2004 WANT START IN NEUTRAL
If you think that engine has a carburetor, then I highly suggest you bring it to a qualified Suzuki technician.
cook 43
found out that this motor does not have carbs fuel injection sorry can anyone be of any help!!!!!!:
99yam40
pick up a service manual for your motor and the proper test equipment if you are going to work on it yourself.
These new motors are not like the old motors, too much electronic stuff and computers involved now a days
Maybe best to have a dealer at least check it out
