Terry In the Philippines
- Apr 9, 2023
- 10
Thanks for taking the time to read this, and also in advance for any advice or suggestions.
I've a DF150 with a bent prop shaft that I am trying to remove. Gear selector has been removed, the 2 bolts that hold the bearing carrier are off, but I cannot get this unit out. I've tried the slide hammer method with heat, I've tried a modified bearing puller on the carrier unit, both methods yielded zero results.
The only thing I did find was that using either method, once outward pressure was applied to the prop shaft/bearing carrier, the drive shaft would sieze up until pressure is released. So I'm wondering what is stopping this unit from coming out?
Your tips, tricks, and advice are greatly appreciated.
Thanks again
Thanks again
