Suzuki df140 twin engine rpm problam
danu
hi i need some experts advise about twin suzuki df140 rpm prob , this two engine not getting rpm more than 3000 when it was neutral and gear position, i think 3000 is normal in neutral position but gear position it should go up, this two engines have 2 separate fuel lines with filters. can be same time some thing wrong in both engine fuel system? or neutral switch problem?
99yam40
Re: Suzuki df140 twin engine rpm problam
test, test, test
That is the only way to find out
