Suzuki df 70 charging cable?
predator165
Hi i have a df70 and need to run my alternator cable separate to front of my boat . and not combined with starter cable.
How can I locate the cable i need?
I believe this outboard has a rectafier i was told?
ron
reeldutch
Re: Suzuki df 70 charging cable?
are you talking about the white cable with a fuse on the end?
thas the keep alive wire for the ECM
you can either hook that up to the positive battery lug or to the battery switch.
on some control boxes there is a connector with a white wire you can connect it on there to, instead of the motor to eliminate another long wire going trough your boat.
hope this helps you
