catchoftheday
Thread starter- Joined
- May 2, 2010
- 1
i have a 1984 suzuki dt 115 outboard! i broke the pivot pin that goes thru the little shutter valve for the choke. I looked at an online manual for this motor but it does not show this part as one you can order and is not separate from the carb! I am not sure exactly what the pin is called but i can describe it! it is approximately 2.5 to 3 inches long and has a flat spot in the middle with 2 holes in it to attach the choke shutter! on one end it has a hole in it for a cotter pin and the other end is square. if anybody can help i would appreciate it because i am desparate to get this motor running! thanks a bunch
