FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
Well I screwed up. I bought a 20 ft Grady White with a 1996 Suzuki 225 EFI and when I got it home noticed that the lower unit is cracked -- just behind the prop. Is this repairable?
Maby, but after the repair, the bearing, seal housing should be remove and cleaned once a year. Corrosion betwreen the gearcase and bearing housing splits the case. This is part of scheduled maintenance.
You might see what your state laws are concerning buyer remorse and try and take it back. If any promises were made in writing such as everything works or is good or water ready you could use that as ammo as well.
