b_arrington
Thread starter- Joined
- Aug 13, 2018
- 13
Need to change the impeller on a 2006 Suzuki DF2.5 4 stroke. The service manual says to release the lower unit, the power head needs to be removed. Step 1 is: Remove the four engine mounting bolts.Detach the power unit with the lower cover.
I've done this, but the power unit seems to be firmly stuck. Any tips / suggestions for removing the power unit? I used a screwdriver and deadblow hammer to carefully tap on a couple spots where I can access the block through the plastic housing. The unit seems top have shifted side to side / rotationally, but I see no movement off the shaft.
