Dantheman123
Thread starter- Joined
- Oct 5, 2011
- 2
Hi all,
First of all i have two problems with my outboard, the first is Im trying to drop the lower unit but apparently i have to disconnect something under the third carb and not to sure what this is because there's a few bolts under there and do not want to undo anything which has nothing to do with the lower unit.
The second is that a while back a buzzing noise came from the control unit and then when i turned the engine off in finished, someone has told me it can be the engine telling me its getting to hot but then somebody else said its my oil pressure being low...the funny thing is that it was oil injection but i go it disconected so the oil was in the petrol. therefore this buzzer should not come on due to low oil levels...it also comes on when its standing in the drive way and i put the trim up to high? with the engine not even running?
Any suggestions would be helpful....
Thanks...
Dan!
Thanks...
Dan!
