Suzuki 140 2006 17 pitch
epresutti
Folks,
I am running a Suzuki 140 2006, with a 17, just finished the break in and trying to run WOT.
I have an 18' semi-v hull
Whole Project: http://www.granvilletech.com/Default.aspx?tabid=53
That I just finished rebuilding, I am trying to get advice on the prob size. At WOT I am turning about 5800, and getting 39mph.
Any and all help would be greatly appreciated. Are these numbers good, or should I see better speed at WOT.
Thanks in advance.
Peace.
Ed.
walleyehed
Re: Suzuki 140 2006 17 pitch
5800-6000 is good and 39 don't sound bad for a 17P on the 115. Is the 39 GPS speed?
epresutti
Walleyehed,
Thank you. Motor is a 140, did you mean that or 115(in your post)? 39 was the GPS speed. Thank you again. Please advise.
Peace.
Ed.
walleyehed
Wow!!! don't know where I got the 115 from????
Boat must be a bit heavy...I would have guessed at a 19P or more on the 140 on an 18ft'r of that type...
Are you using a Suzuki prop?
epresutti
Walleye,
Thank you, prop was given to me (free was a good price based on my budget), it is a Suzuki, I was thinking bigger than 17 just didn't know.
Mechanic was telling me he has a 20 Stainless. I will definately try a bigger prop and see what I get.
Boat may be a little heavy, don't know the weight, also have a slight list to port on plane.
Still getting things trimmed out, when the motor is pulled all the way in, the cavitation plate is 1" below transom, I like it that way, gulf can get a little rough at times. When trimmed back 1/2 way cavitation plate is even with bottom of hull.
Thank you much, will be looking at alternate props. I have an opportunity to purchase 20 stainless for $150, what do you think? Was used on a demo boat and is un damaged.
BTW: If you are looking at Florida, stop by, I live on St. Joseph sound north of St. Pete. Actually, I live across the street from the canal, neighbor lets me use davits and dock, 5 min idle to the channel, then mexico:)
Peace.
Ed.
Tail_Gunner
8) So Ed are you looking for top speed or stability, seeing you have a outboard you have a lot of option's as to prop type's and all the thing's that can be acclompished,
Sure look's like you have a deep v there and you like it trimmed in? (stablity in a heavy chop?) Maybe you need a overall lifter or stern lift prop.........8) Better let the pro's make a recomedation there, maybe a turbo ULTIMA 4 or TURBO 2+2 20 pitch.
epresutti
Tail Gunner, et al.
I am really looking more for stability (saftey) than speed.
I was out today with a pretty stiff wind and kept everything trimmed in and ran fine. When you get between the islands there can be some serious rollers, I like the prop in the water :)
With the V I am handling the chop very well, when on plane I can trim out a little ways get more RPMS and get the bow down where I like it.
So bottom line, stability and max performance, not squirly speed :)
Peace.
Ed.
walleyehed
If we go to a 20SS, that will be like a 21P aluminum, and likely put us in the 5000+/-100 area...a no-no for that engine..
BTW, a 2+2 has alot of bow-lift...I don't think that's the direction we want to go..
What I "Really" don't understand (and yet, I do????)
is why would a Mechanic tell you to try a 20P SS if a 17P is not even getting to the top of the RPM range...???
EDIT: This engines Max RPM range is 5600-6200.
I also found some test data on this engine on several boats...in one test on a 19-1/2ft Deep-V fiberglass, they ran a 20P SS at 6000RPM and 44.2mph at a weight of over 2700lbs...
That engine should have hit the rev-limiter with a 17 on your rig. This engine has a 2.38:1 gear ratio and "should" swing a much higher pitch prop.
Did you put a new suzuki tach in when you installed the engine???
epresutti
Walleyehed,
All guages are new and Suzuki. Motor was rigged by authorized Suzuki mechanic, maybe throttle cables need to be adjusted? He did say I would hit the rev limiter, but that has not been my experience.
I think at this stage I might want to get him back to tweek the installation. I may want to bring it back to the lake for some smoother water to run a few tests.
Any further thoughts?
Please advise.
Peace.
Ed.
walleyehed
The 17P suzuki prop is what one of my customers is running on a Johnson (suzuki) 140 on a 26ft pontoon...so I am sure something isn't right...
epresutti
walleyehed,
Thanks much, I will definately find out what is going on.
I appreciate all the feedback.
Peace.
Ed.
