barthel
Thread starter- Joined
- Mar 20, 2012
- 94
Hi All,
I have an '01 Four Winns Horizon 180 on a single axle trailer. Trailer is equipped with disc surge brakes. The brakes had never worked, the system was gunked up and corroded when i bought it.
So, after going through the entire system, the last part to replace was the solenoid. I removed it, it was totally clogged and shot. Bought a replacement and installed it. The difference was, the one i pulled out was a single wire (hooked up to tthe reverse circuit), the one I installed was a two wire. My understanding was that it didn't really matter which wire was connected to which, as long as one was power and one was ground (please correct me if that's wrong) So I hooked one wire up to the reverse pin, the other was grounded to the white wire (gound) on the trailer pigtail directly.
Anyway, the surge brakes work awesome now, but the lockout solenoid does not work in reverse. When we back up, the brakes lock and I have to use the manual lock out. I have checked all connections and everything checks out. Lights and everything else works OK.
So, do I swap the leads? Is there something I missed or do i have to replace the solenoid with another single wire?
Any help or opions are greatly appreciated.
