Got an older Atwood surge brake actuator on the boat i just got.
Had the ball jammed in and couldn't remove.
Took the actuator off and noticed the lever inside that moves the lock forward/back is stuck ABOVE the locking piece aka is moving in wrong direction and doesn't let the lock fully disengage, holding the ball locked until you unbolt the whole piece.
There's a large PIN-like bolt which has no way to unscrew it to remove spring and metal latch to fix their position.
Has anyone seen anything like that before? Any ideas how to fix or move the latch in correct position again?
Would like to fix ASAP, got the new actuator ordered, but everything is out of stock in Canada for last 2 years so it takes 2 weeks to get it.
