surface gap spark plugs
dicktaber
Your opinions? I had a set in my 1972 50 HP Johnson; seemed to work well. Finally fouled one Saturday after about 45-50 hours total use (this year and last). Replaced with standard NGK B9HS, runs great--should I buy another set of the surface gap plugs or just stick with the normal type?
D
DJ
Guest
Re: surface gap spark plugs
Knot,<br /><br />If the "normal" type work OK for you, stick with them.<br /><br />I have always been told that the surface gap type were better for sustained high speed running.
