sure hope this fits!!!!
OBJ
Re: sure hope this fits!!!!
That one don't work either ts....do you know the year of the lower unit?
tschamp20
im sorry if you go to ebay and enter 140004962363 into the search bar it will take you there.
tschamp20
youre one of the guys i hoped would look.thanks for your time.
Water Plug
Description from seller at ebay:
EARLY 70S , 115HP BUT WILL FIT MANY HPS AND YEARS , GUARANTEED TO WORK PROPERLY,SHAFT LENGTH FROM BASE OF WATERPUMP TO TIP OF SHAFT IS,21-1/2 IN,COMES WITH STAINLESS PROP ALSO IN GOOD CONDITION,AS ALWAYS CHECK THE IMPELLER B4 USING, SHIPPING IS 55.00 IN US
I would guess year of the lower unit is 1970 to 1975 ( just a guess) but I would urge you to contact the seller to find it age before buying it. :/
If you look for the complex,
you will always miss the simple.
Brian~
tschamp20
yes the pix on ebay look the same
OBJ
If the year is within 73' to 77', you shouldn't have a problem bolting up. Not sure if if the gear ratio's were the same though between the different hp's that used the CF block. Part numbers are not the same for the gears and pinion. But, you can't beat the price if it's going to be a "plug and play" part.
tschamp20
well from my research last night,johnson only made a 115 in 1970 not in '71,'72.he claims early 70's 115hp so unless it came from a 1970 i should be straight if not could always sell it again on ebay.ill have to wait and see.
ezeke
Stop worrying. The earlier ones were electric shift. You have a shift rod from the 73-77 series showing in your pix.
tschamp20
now that is the kind of thing i wanted to here.good call.your the man!
