drewmitch44
Thread starter- Joined
- Jun 26, 2005
- 1,749
I have a sump pit with 2 water ace 1/3 hp submersable pumps. The water table here is high and I have been having problems with water for years. The water comes into the sump pit and it is clean water. The pump will turn on about every 10 min or so. I have 1.5" PVC pipes running all the way out of the house where it turns into a 4" couragated pipe underground right in the front and goes to the ditch. These pumps are constantly breaking down! I am about to switch brands or something. I have to go and shake the float sometimes to get them to kick on. The floats can be completely under water and still they do not kick on. What do I do? Is there a better brand of pump and is there a better set up? I have the pumps set up so I can change them out quickly and there is 1.5" check valves on both PVC pipes on the way up the wall. Thanks for any help, advice, experience or any other info you can give me!
