I'm about to dive into a project. I'm in the process of getting my hands on a 1976 Sport Craft tri-hull bow rider that I am going to turn into a center console bay boat. I've not even seen this boat yet, but I'm getting it simply for the cost of the title fee. At this point, I have to assume that all of the wood is shot and I've got a lot of fiberglass work to do. Well, whether it is shot or not, I KNOW I've got lots of glass work to do! I'm not a stranger to it, but I did my last fiberglass project in the very early spring when outside/garage temperatures were nearly perfect. If I get finsished with the disection say in mid July, the first batch of polyester will be applied when the mercury is still between 90-100. I need to know how I should adjust my chemical mixture so that my goop dosn't prematurely kick off in this heat.
Another question I have is about finishing coatings. I plan on painting the whole thing with Awlgrip, or Perfection...haven't decided...way ahead of myslef for the present stage. But if I'm going to paint everything with an epoxy based paint, do I need to apply a coat of gelcoat over the raw glass, or is primer and paint sufficient without gelcoat?
Nearly all of the wood is going to be replaced with nidacore. I know it costs a little more, but I like working with it and the weight adavntage. Spaking of weight, is it possible to make it TOO light? Basically, the nidacore is going to be used for the stringers, deck and some above deck construction. The transom will still be wood and I am planning on having about 40 gallons of fuel, bow mount trolling motor, two batteries and maybe a 30 gallon bait tank in the bow. Minus the wood floor, seats and consoles and add all the above, I'm figuring on at least a 200-300 diet from the original construction. The previous owner said that he used a 55hp and it pushed it just fine. I'm affraid that by cutting so much weight, this thing will launch smooth out of the water at WOT with a 55. Am I wrong? Oh...the boat is a 16'. I just want enough power for the boat to glide along comfortably with four adults with power to spare, yet I don't want it chine walking when I'm by myself, or when my kids are by themselves. I'll start a whole photo-journal once I get this thing started.
