So is the gauge in the boat? If it is the test process is the same AFTER you make sure it has +12 volts, ground and the paddle wheel connection is secure on the gauge. If any of these are missing, fix it and go for a ride. If the gauge still doesn't work it, the paddle wheel, wiring between them, or all of these need repair. If the gauge is out of the boat you can't test it without the paddle wheel.
