Re: Suggestions on screwing into fiberglass
For reference, here is a link to your other thread on this topic:
http://forums.iboats.com/showthread.php?t=446941
I like the pine tree (xmas tree) clip idea of Woodonglass, though may I recommend you consider double-ended like these:
http://www.itw-fastex.com/catalog/index.php/dw/op/a/7/c/17/p/15?m=no
And perhaps do away with the upholstery buttons altogether. All those do is snag fishing line and bathing suits, anyway
(BTW, you can order free samples from that link)
I do wonder though, IIRC you said these are made from vinyl-wrapped foam stapled to wood, yes?
How much wood? How thick is the foam? How large are the cushions?
How heavy are these, and how heavy are they
going to be when the foam absorbs moisture (which is inevitable)?
(I'd love to see some photos posted of the new cushions, front side and back, and a description of their construction)
What I'm getting at is, I am wondering if these things will be
too heavy for plastic Xmas tree clips, or even for the holding power of velcro?
(Maybe the butt-cushions can use glued-on velcro just to keep 'em from sliding around, but I worry about the "vertical" cushions)
Someone in the prior thread mentioned z-clips or upholstery clips. That works well for holding heavy cushions, but those can get to be VERY expensive, particularly in aluminum or stainless (i.e., non-rusting).
If it's not too late to take apart and re-staple, you may want to consider some sort of through-bolting.
I see from your pic that this is an open bow trihull. I assume you can easily get your hand up under the gunwales in the cabin, but can you do the same with where the cushions in the bow will go?
If so, you could maybe re-engineer your cushions such that you use 1/4" stainless steel T-nuts in the wood, like in this thread:
http://forums.iboats.com/showthread.php?t=397623&highlight=stainless+t-nuts
(BTW, that thread also has links to the thread(s) where the T-nut idea came from)
Then you use 1/4" stainless hex head bolts and fender washers from the rear to through-bolt your cushions into place, length depending on the thickness of the "wall" you are bolting through. Again, this will work only if you can get your hands and tools up under where the bolts have to go.
That's how I re-did my open-bow trihull, and those cushions ain't never coming off unless I want them to.
I considered all those options and more:
Xmas tree clips: fear would be too weak
Velcro: ditto
Snaps: ditto
Z-clips/s.s. upholstery clips: too expensive
Before deciding through-bolting was the way to go.
BTW, good online source for inexpensive stainless hardware, buy anywhere from individual pieces to mega-packs:
www.boltdepot.com
