hullofalottatrouble
- Jul 16, 2005
- 306
Mercruiser 260 5.7 350 V8.. <br /><br />Okay here is my story in a quick review...<br /><br />Last summer had overheat situation.. didnt get excessively high but ran right under the red for a very prolonged period of time at very low speed.. (long story and yes it was stupid).. pulled plugs after run and were oil fouled<br /><br />boat got a full tuneup at shop when took it in for overheat.. they didnt fix the overheat by the way.. <br /><br />i later fixed overheat problem<br /><br />Fixed shift cable that went out<br /><br />Ran boat again. Didnt overheat was at good op temp but after going back to idle started running a bit rough and stalled when going into gear.. friend close choke down a bit when i shifted and it went into gear and ran.. thou again rough and idle never stalled at idle.. and again had ot have friend close choke down a bit.. to get back into gear.. pulled plugs again and again oil fouled<br /><br />figure bad fuel to air mix so checked fuel line.. found bad antisiphon valve.. fixed it.. fuel flow to carb fixed.. <br /><br />ran again..again ran a bit rough at idle.. and had hesitation when going into gear but not always stalled.. stalled once but mostly just hesistation then into gear.. <br /><br />got back.. pulled plugs.. fuel fouled..<br /><br />winterized the boat<br /><br />went to unwinterized and noticed fuel in the oil..<br /><br />changed the oil.. adjust carb needles to 1.5 turns out.. <br /><br />got boat started.. no leaks anywhere.. no water in oil.. but idled a bit rough at first but picked up.. <br /><br />had vacuum gauge on.. ran at 10-12 pretty steady no huge fluctuations at idle which is low.. <br /><br />throttle up and down quickly and gauge went from 0 to about 20.. and back fired<br /><br />any slow throttle up and it hesitated.. a bit<br /><br />I need to do a new comp test now that i have a new started battery.. didnt trust the old batt but when i did it with old it was 100 in 1 cyl and 125 in the others.. i guess even with low bad that 1 cyl stand out as a problem.. <br /><br />note that every time out on the boat after the overheat was short and just to test the result of the overheat fix.. shift cable fix.. and fuel flow fix.. <br /><br />i am fairly new to this boating thing but enjoying the hobby... just looking for some suggestions.. time for a leakdown test? Anything else? These results already clearly pointing to shot rings? <br /><br />I would like to avoid playing $1500 for a rebuild if possible but am not going to shy way from spending the money if thats the right thing to do...<br /><br />Thanks for the help/thoughts.. kind and unkind words..
