suggestions for ladder for 2001 crestliner super fishhawk 1600
Any of the commercially available ladders
jsaylor
I'm asking for recommendations for the ease of install and fitment
roscoe
Can't tell you a brand, there are so many from generics, to high end brands, to cheap chinesium.
Just make sure you can configure it to your mounting space.
Here is mine on my Starcraft. A bit of unconventional mounting, but it works and swings down without hitting the transducer.
Make sure the bottom rung extends low enough so you can actually get your foot up onto it when you are down in the water. Mine extends about 40" below the water surface.
Do you want it permanent or temporary, off the transom, bow, or gunwale?
You can look at the GG Schmitt online ladder catalog. https://www.shopggschmitt.com/
These are OEM to many of the boat brands
airshot
You should have one that can be deployed from the water, won't do much good if your in the lake and the ladder is up inside the boat. I have figured out a way to board my 16' by using the power tilt and trim. Not easy but very doable.
