1900clueless
Thread starter- Joined
- Mar 13, 2016
- 18
Where to start? Began with a gas issue: Rebuilt carbs corrected leaks in carb bowls, pinched wires to fuel pump (no damage to wires ). Also some gages not working. Replaced Rectifier/Regulater, tach. now working. gas gage fixed. power to other gages, but not working (water , trim) .all oil lights and Alarms are working. Stated up ran until cabs ran out of fuel, replaced VRO pump. Corrected leak in fuel line.
Stated engine, idled good , oil ok, fuel ok, Suddenly motor dies, will not start, plugs wet, fuse at motor ok. No spark so while running , using garden hose to supply water while it was last running I noticed the hose had a kink in it, some water was going to motor, the motor ran about 3 min. prior to shutting down at idle. Is there a connection between water pump and ignition ? Any thoughts on spark issue?
Some of these issues are in my forum topics prior to this one, this is an attempt at all recent history, incase they are related or tied to each other. Seams like a kill switch. but I am clueless.
