Stupid motor!!!! Aaaghhhh!!!
Saltlife8268
I have a 92 johnson 120. Took it out the other day had no problems. The next morning she wouldn't start. Will crank and run for about 8 to 10 seconds then it will just shut off. I installed new plugs, plug wires, fuel pump, all new fuel lines, filters, primer ball, cleaned and over hauled all carbs. Have it running off seperate fuel tank. I checked spark on tester and it is jumping the gap but it's a faint whitish spark not a strong blue spark. Could this be the problem? If so whT do I do next. I unplugged the red plug under cowling and jumped the solenoid to rule out ignition switch and still have the same problem. Thanks for everyone's help!!!
check and clean all the ground points on the motor. Then see if you can borrow a timing gun and check that the timing is close (don't need to adjust just checking the key hasn't sheared under the flywheel). With the timing light clipped on start the motor and see if the plug stops firing (light will stop flashing) or if something else is stopping the motor.
Saltlife8268
I found the black wire with yellow stripe under the power pack. I disconnected it and nothing happened. So I disconnected a yellow wire with red stripe at the same time as the black/yellow and she fired right up and idled for about 20 minutes until I had to flip the red lever on the choke solenoid to shut her down. The key switch would stArt it but wouldn't turn it off. I started it back up and took it back out on the water. At first it wouldn't get on plane even with throttle lever all the way down. Eventually it did and at about 4k rpms it would die back a hair then surge forward. Then it would just completely die but then start right back up. It did this several times before I took it back in. It seemed like it was killing the battery very fast as well. Sooooooo.....what do these two wires go to? And are they what are effecting engine performance. Thank u all again for your help!
