I have a 1989 Evinrude 70 hp, 3 cyl, that runs like it is in slow mode. Is not overheating, 135 degrees Fahrenheit, alarm system works good if temperature sensor is grounded. I have disconnected tan wire to sensor and power pack with no change in how it runs. Firing on all three cylinders good with about 125 lbs compression on each cylinder. Carbs have been rebuilt and cleaned. New fuel pump and primer bulb, tried pumping bulb while running with no change in performance. I've gone through and checked reads, no damage or cracks.
I'm completely stumped, thanks for any help
