Stuff that's wrong with my Ford....
i386
I have a '98 Ford Explorer Sport (2 Door, 6 Cly.)
I've had it for about 7 years. It's the first vehicle I've ever owned with any of the following: Automatic Transmission, Electric Windows, Electric Seats, Keyless Entry, Cruise Control. I thought I'd bought a Cadillac when I first got it.
I keep the oil changed and it still runs pretty well. No complaints on the engine at all really (knock on wood).
The list of stuff that doesn't work on it just keeps growing. Here we go in order of failure.
1. Rear wiper. Must be some weird design flaw. As the wiper begins its arc across the glass it also lifts off the glass only to make contact just before the end of the arc. So it never effectively touches the glass. And that is when it moves at all. Sometimes it just doesn't do anything. I took it to the dealer and Skeeter/Bubber just bent it a little and said "air ya go". No improvement.
2. Stereo display, or lack thereof. It comes on about twice a year and stays on until I turn the engine off. I take advantage of that time to update my presets and set the clock.
3. Seat recline handles. They both rusted and broke off. No salty environment here. wth?
4. Cigarette Lighter. Fuse is good. Replaced lighter. cleaned out the socket. Still doesn't work.
5. Driver's side door lock. Usually won't unlock unless i slip a fine point needle nose pliers under the door handle while actuating the electronic door lock. I crawled across from the passenger side for about a month until I figured that trick out.
6. Mysterious freon leak. I added 2 cans last summer. Cooled like a champ for about a week.
7. Drivers side window washer. Nothing comes out. Passenger side of the windshield gets a good squirt though. Maybe I should just drive from that side so I won't have to climb over.
8. Heater is always on. Turn the knob to red or blue side. Doesn't matter, blows hot air.
9. Drivers side brake light. I buy bulbs in gross and have replaced the factory phillips screws that hold the light in with t-handle speed screws. Not a problem anymore.
10. Hood lift springs. They won't hold the hood up anymore. I have a piece of 2" pvc pipe wedged in between the battery and fender that I pull out to prop it up.
Stay tuned. More to come I'm sure.
Reel Poor
Re: Stuff that's wrong with my Ford....
Now you know how they got their nickname, Ford Exploder. :p
roscoe
I bought a 1998 4 door explorer last november.
1- rear wiper, same problem
2- stereo, no problem
3- seats, fine, but they can't smooth out the ride
4- lighter was missing when I got it, have not replaced it
5- locks, no problem. But if you have the key fob with the remote lock, be advised that it will not work if the car is running. (don't ask.)
6- Why would I need air conditioning? Have no idea if it works, because it hasn't been warm enough to try it yet.
7- washers, no problem
8- temperature control has failed. The temperature blend door inside the plenum is no longer attached to the actuator shaft. $700-$900 fix at the Ford garage. It can be done with a redneck fix, a dremel tool, and 4+ hours of your time. Turning the defrost/heat control to "off" will stop the hot air from entering the passenger compartment, but it sure ain't no fix and offers no temp control.
More info on how to fix it:
http://autorepair.about.com/library/illustrations/bl332a-lib.htm
http://autorepair.about.com/library/faqs/bl958g.htm
http://www.ford-trucks.com/article/idx/12/085/article/Ford_Explorer_Blend_Door_Fix.html
9- no problem
10- no problem
Bob_VT
Most are common problems to the exploder.....
#1 - First I have heard
#2 read on the net and if you are adventurous you can replace the stereo lights w/bulbs from radio shack http://www.ford-trucks.com/forums/595076-dark-ford-radio-display.html
#3 common but I do live in a salt on the roads area
#4 have seen the hot wire burned behind the dash - check the wire
#5 door panel must be taken apart and leaned and lubed... chack all the tiny clips
#6 .....answer is cheap metal lines that rust away ..... very common
#7 have to take that thingy off and clear the crud out of it and the line too...... try a needle or a dental pick
#8 Temp control ----- go to a junk and replace see Roscoe's answer
#9 my bet is on the socket..... replace the socket in the light
#10 just worn out poor quality
It's 9 years old and probably worth $2000-2300 for a trade in..... maybe it's time :/
rwise
Fix
Or
Repair
Daily
oppppsss d:) I had to say it d:)
i386
Yea that's the plan... Wife stopped working to finish her masters. She's going to be a teacher so I'm bringing home all the bread right now. Both of our vehicles are paid for. We're planning on getting a new truck this summer. What do get is what I'm stewing over now.
I need a truck. Hooking up the utility trailer to the explorer is getting old. The heaviest thing I'd be pulling is small boats and most of my driving is in town. It's really hard for me to justify a full sized tuck with a V8, even with the new features that shut down half of the cylinders. So I'm looking for something with a V6. I'd like to buy an American made truck but I just don't see anything in that size worth having.
1. Ford Ranger. No more Fords for me, sorry.
2. Chevy Colorado. Dang good looking truck from a distance IMO, but up close it looks cheap. So does the interior.
3. GMC Canyon. See #2.
4. Dodge Dakota. Already had one of those. Not going that route again.
5. Nissan Frontier. Not super crazy about how it looks. Looks kinda cheap on the inside.
6. Honda Ridgeline. IMO that ain't a truck, sorry.
7. Toyota Tacoma. I can't find anything I don't like about this one except it isn't American made (tm). They retain their value very well too.
Anybody have 19' fiberglass bass boat with a 200+ HP engine on it they want to give away. If I had that I could make a pretty good case for that Chevy Silverado! 8)
Vlad D Impeller
" 8- temperature control has failed. The temperature blend door inside the plenum is no longer attached to the actuator shaft. $700-$900 fix at the Ford garage. It can be done with a redneck fix, a dremel tool, and 4+ hours of your time. Turning the defrost/heat control to "off" will stop the hot air from entering the passenger compartment, but it sure ain't no fix and offers no temp control."
This is a very common problem with Ford trucks and SUV's of the latter 90's, i don't know if they have rectified this in their later models or not, but in my case i did once wrote to Ford about this very popular occurence with their vehicles, anyway they refused to admit that it was of poor design and shoddy craftsmanship, which i still do believe it to be.
My next truck will definitely be from another manufacturer, i have been looking at the Toyota Tundra, it appears to be a rather fine looking vehicle, though i have not researched any details about it.
i386
Good info Vlad...
In years past I have regarded the Tundra as non-remarkable to look at. The new ones look pretty sharp to me though. I am sure they're good trucks. I was comparing them to the Chevy last night and was surprised to see the Chevy had better gas mileage. As an investment though, I bet the Tundra holds its value better though I haven't done my homework on the full sized trucks like I have the midsize ones.
xtraham
Mike, the Chevy Colorado has
less problems than any other truck in it's class
next inline would be Dodge dakota,
ndemge
My 84 Ford pickup:
-Just a list, I know what is needed to fix, but more to show lovely things about old vehicles if you let the bad things pile up.
Ignition switch, after starting, need to turn the key slighty back to get break/blinkers/radio working.
Right Turn signal indicator burned out
Heat/cool selector no longer works/pieces broke behind dash, so always on heat. In the spring, I take the 2 heater hoses and connect them to bypass heater core.
Accelrator pump in Carb not working, so have to really feather the throttle to take off. (brother has offered to rebuild carb)
Left headlight points at the ground from brother's accident in the driveway
Dome light works if you hit it.
-Dome light plastic cover broken from hitting it.... light still works though..
Hydraulic clutch, pedal sticks when letting it out 1" from the floor, have to spray lube into assembly under truck every 2 months.
Drivers mirror moves every time you close the door.
AC works great.... November-February
i386
Tom, I'll check into that and give 'em another look. The ones I'm seeing on chevy.com look to have a lot more available features than the ones I saw on the lot. Maybe they were just striped down models.
I just don't care for the Dakota.
xtraham
no influence intended,
those models are just the least that I see in for repair for that size truck
tommays
This would be why i own a Silverado WORK package
Rubber floor Nothing but AC and Automatic trany
Not even a clicker for the doors to break :)
I would think they all make a model without all the fancy stuff to cause problems
Tommays
i386
Heh, that's the thing. I want some of that fancy stuff, I just don't want it to break. I also want something that'll be worth something when it comes time to trade again. It's sad that my '99 Honda 750 Shadow is worth than my Explorer.
Mark42
For the wiper problem, open the tailgate from the inside. The bottom mount for the wiper often comes loose and the bolt falls inside. Its a special bolt meant to go with a rubber grommet. If it is lost, then you can fabricate something from fender washers and a bolt and a piece of innertube rubber to keep noise down.
To test for this condition, open the rear hatch half way, then quickly raise and lower it like you are trying to shake the wiper mechanism loose inside. If you hear a rattle or a bolt bouncing around inside, you probalby found it.
BTW, the inside plastic is a pain to get off without cracking be careful, use putty knifes, not screw drivers to pry loose.
Remember that truck is almost 10 years old, what do you expect? It is just wearing out!
i386
Mark, I took that off about 5 years ago and couldn't find anything loose. What I did find was that the whole mechanism was mounted by 3 bolts and the metal in the tailgate flexed as the motor ran. Had it been attached by 4 bolts I don't think it would happen. You can put your hand on the motor and wobble the whole business easily. Might give it another look, but I do remember scratching my head last time I had it apart and thinking wtf were they thinking when they designed this.
The wipers and seat handles are my biggest gripe. The other stuff I can agree with about it being 10 years old.
One other thing I forgot to mention is the suspension. If I hit a bump on one side (not both like a speed bump) it rocks so violently that it'll just about throw me to the other side of the cab.
On a positive note I will say this. She's never left me stranded and the brakes work very well.
Bob_VT
You better re-investigate where it's made and source of parts.......
More american than Chevy Dodge Ford..........
i386
Bob, I knew someone would bust me on that technicality. I believe they're made in Fremont California.
stevieray
I guess I'm lucky - I bought a '96 Explorer XLT new in Sept of '95 & have been using it as my daily drive ever since. Has been in the shop for other than routine maintenance exactly 2 days - once for the front stabilizer link recall (and I got the free set of tires from the Firestone debacle at the same time) and once for a rear output shaft speed sensor that kept 4WD from working.
Must have been built on a Tuesday. 8)
