Stuck
Spiralers
silvertip was right you shouldn’t buy anything before yu have a plan .im stick with a no.5025 6 circuit st blade fuse block.so
what im gonna do is use like a negative and positive buss bar.my boat is 15 ft.i am going to run a 10 or 12avg both positive and negative to the fuse block which is will be under my dash.the run will be about 10ft .20ft both ways .my fish finder is on the dash and the running lights on a dpdt switch.the bilge is in the stern .i will run it to the battery using a 3 way switch,of manual ,off.auto.im figuring 16avg for the accessories.the only thing I’m not real sure about the size of the fuse near the battery on the 10
or 12avg. If I’m off base please correct me.
Silvertip
Honorary Supreme Mariner
Use a 20 amp "breaker" for 12 gauge or 30A for 10 gauge wire. Don't use a fuse in that circuit..
