stuck in the gimbal housing, look.
Primo321
Good Morning All,
Working on getting this trim hose off my alpha 1. The hose is blown and needs replacing. Was able to work it out until I ran into the part of the steel portion of the bellows that extends out about a half inch attached to the transom. a standard wrench no longer fits and cant give it the last few spins that it needs to fall.
Anyone run into this problem before?
its the hose facing parallel to 3 oclock seen here.
Additionally I discovered my neutral saftey switch is broken, how necessary is this piece?
I am having trouble locating the replacement part#, im sure its obsolete.
1969 mercruiser 140
Any help would be awesome.
Thanks all
pevaguy
Re: stuck in the gimbal housing, look.
First pull the leg off, then remove both bellows. Using a propane torch, heat the block the line is screwed into. Using small needle-nose vice-grip pliers unscrew the line. Here is a link to Sierra showing the lines you need (I recommend replacing all four while you have it apart). http://www.marineengine.com/parts/s...ngine.com/parts/sierra_marine/sierra00729.htm Sierra dose not have all them available but you can use their part numbers to do a google search to find a source . Good luck, I have been where you are now.
