Stuck in reverse after lower unit removed for waterpump. Evinrude 200HP YR2000
JET OWEY
I only have reverse now in all shifter positions - forward is reverse and reverse is reverse too. It even starts in reverse which made for an interesting drop in at the yacht club yesterday. Evinrude Fitch 200 HP Yr200. While trying to do lower unit seals (the seals located under the water pump) after the mechanic left, we did fiddle with the shifter at the helm while trying to figure our how to disconnected the shifter rod (turned out to be a 3/8" screw/bolt located centrally on the engine.) It is possible we reassembled the shifter rod while the helm was in reverse position. I'm in the water, be great if can fix while on-the-water.
Any suggestions besides hiring someone else to fix my mess-up --any tips? (PS It is not easy to find mechanics around here.)
Memo to self - don't break what is not broken, this was to be a preventive water pump replacement.
Thanks in advance, regards.
JT
steelespike
Re: Stuck in reverse after lower unit removed for waterpump. Evinrude 200HP YR2000
Your in the prop forum you need to post in the Evinrude/Johnson forum.
I'm guessing you would assemble the shift with the control in neutral position
and the motor in neutral.
JET OWEY
Should I repost in the proper area? (not sure if I can delete)
Big flop
Are you sure the shift pin/bolt went
thru the hole in the top of the
shift shaft rod? It sounds like
it may have missed
JET OWEY
Big Flop - you nailed it. I missed the screw to secure the top of the shifter rod. It actually hide below a little rubber shroud.
THANKS
