Stubborn Gearcase Drain Plug on 98 OceanPro 200
G
Guest
Guest
I'm sure this remedy is buried somewhere on this blog, but there can never be too many to address this problem because this effects all motors:
The gear case drain plug on my 200 Ocean pro won't move. I have a big screw driver to fit the slot in the plug, but when torque is applied by hand, the blade slips out and tries like Hell to jimmie the slot.
I was wondering if I could use an impact driver on this?
Does anybody here have some tried and true remedies?
Crosbyman
at the very least try to use a flat blare screwdriver with a square shaft so you can had some torque with a common wrench ....
​I have used the smaller impact screwdriver with a flat bladed 3/8 socket & adapter
dingbat
When you get it out, throw it as far out in the field as you can and buy a plug with an Allen key
Crosbyman
well personally .....I had both the allen and slot types...on my 75hhp .and when you strip an Allen type you ate deeper doodoo and you have to make a slot to screwdrive it out .
it is critical to use the proper sized flat blade screwdriver ...wide and thick enough
​jmho....btw I prefer to had a bit of teflon tape on the threads but to each his own.
