Stub-oh-run Johnny
CsBreeze
1971 13? Boston Whaler
1971,'2,'3 25Hp Johnson (pull-start)
Had to get a tow in last fall when my engine quit & it wouldn?t restart. I thought it was crap fuel or a dirty carb, (I was running a shot of Sea Foam in the tank to help keep the carb cleaner) so when I got home I removed the carb & cleaned it thoroughly. However, upon reassembly, never mind starting, I could not get the throttle handle to turn full range and move the spark advance lever under the flywheel, from Stop/Idle to Full speed. [FONT=&quot]I was messing around with it all winter, snowed into my garage as I was, and haven?t even tried to restart it yet because of this ? It is the middle of July and I'm stuck -- [/FONT]Please help, Shipmates !
F_R
Honorary Supreme Mariner
Exactly what I immediately thought. You can't advance it all the way in neutral or reverse.
CsBreeze
Dang - y'know, I never thought of that... <<DUH!>>
I'll check tonight when I get home from work (pardon my language !)
Thanks guys !
CsBreeze
I got home late, but I went to the Johnson this morning & tried the throttle handle w/ the shift in FWD. It pushed forward a bit (faster) then stuck and wouldn't turn back to SLOW... Guess I better get the flywheel wrench out & take a look under it at the advance plate & the points, etc. Its farther than I've been into the engine before. Any clues on that ? Thanks
CsBreeze
So... I got home & immediately turned to. First - it looks like the gap between the top of the plate & the bottom of the flywheel are not parallel - a tighter fit at front than the back, and I mention is because the tiller throttle cannot move it back to idle. What would cause that ? I aligned the vertical throttle rod that turn is, and that is loose enough, but no matter how hard I try to turn the grip it won't get to idle... I wish it was easier to post a picture to show it... I don't have a puller to remove the flywheel so I can't see the points, either, IF that's even the issue. Any ideas gentlemen ? I'm almost ready to part this PoS out...
CsBreeze
ending this thread - disassembled & reassembled, all parts now move correctly. Still won't start... new questions to post. Thanks Y'all !
