Re: Stripping paint/corrosion from aluminum?
I agree sanding has been the traditional way to remove paint, but it has drawbacks- not the least of which is it is labour intensive, plus the fact that no matter how careful you are, seams, crevices, around fittings, rivets, it is almost impossable to clean the old paint right off.That's exactly why a chemical stripper not only is much less time consuming, it gets those hard to reach spots- exactly where paint failure begins when the old coating has not been properly stripped.<br /> If you go with one of the new generation paint strippers, they won't damage gaskets, or other fittings,or harm the substrate be it aluminum orgel coat, plus are totally benign- they don't burn skin, have noxious fumes or are environmentally harmful.Spray or brush it on, wait overnight, and powerwash it off.You are now down to the base substrate, ready to prime and paint.
