Stripped oil drain plug!
johnboat78
I have a 2016 Mercury 20hp 4 stroke with a stripped engine oil drain. Can anyone tell me if a ‘piggyback’ drain plug will work to fix this? The mechanic said he couldn’t put in a helicoil and a new oil pan would be over $1,000...
find a new mechanic. Helicoil or other threaded insert would be the fix.
alldodge
If the pan is not thick enough a heli won't work. Could remove the pan, and braze or weld a weld nut in place
If there is room, tap to next larger side plug
For that matter, remove, weld closed, drill and tap to original size
jimmbo
FInd out if Merc has a Service Bulletin regarding stripped Oil Pan Drains.
roscoe
Piggyback should work if you can find the right thread size.
Chris1956
Gee, how about using a flush bushing thru the original hole, with a pipe fitting on the inside to fasten it. It would require removal of the pan.
