Hello, I am the one with the 1978 galaxie 22xl that you have all graciously given me advice. One issue I wanted to address was the suggestion of waterlogged stringers.
My boat I believe has carburation problems that are keeping me from getting full rpm at wot. I have now decided thru process of elimination that I have to be running lean.
One person suggested that I could have waterlogged stringers and wet foam adding 1000 lbs to the boat. I know the boat seems to be in very good condition, but I was wondering how do I look and see if the stringers are waterlogged.
Also, I have read on here that there should be holes to allow the stringers to drain water in to the bilge area, is that correct? I do not see any holes in my bilge area that would allow water to drain from the inside of the boat in to the bilge area?
Do I need to pull the carpet and start cutting holes to see this? How do I figure this out? This seems to be an issue that I would like to lay to rest before I spend anymore money trying to increase performance.
Help???
Thanks again!!
Help???
Thanks again!!
